VADUS
[TRACKED] Fingerprint scanner vibrates every time I touch it with wrong finger
Mon Jul 30, 2018 8:15 am
On the 7.0 it was vibrating only after fingerprint has been recognized. Now on OREO, it vibrates every time I take the phone in any hand and accidentally run the wrong fingers on the scanner surface. Actually, it is kind of annoying, and it also waste the battery. It would be nice, if there will be an option to disable vibration at fingerprint recognition at all.
With best regards,
Vadim
Re: Fingerprint scanner vibrates every time I touch it with wrong finger
Tue Jul 31, 2018 1:11 pm
Will forward that to the tech team ;)
Costantino
Re: [TRACKED] Fingerprint scanner vibrates every time I touch it with wrong finger
Tue Jul 31, 2018 1:45 pm
I completely agree with Vadus.....same problem....
rocketman5004
Thu Aug 09, 2018 12:50 am
I noticed that too. The same vibration pattern even sometimes appears when i just turn off the screen. really annoying.
cizas123
Sat Aug 18, 2018 6:48 pm
same here
prascho
Fri Aug 24, 2018 8:34 am
I can confirm this also. Sometimes I pull the phone out of my pocket and I cannot unlock it with my finger because there were already too many failed attempts.
