prascho
Notifications' volume cannot be changed
Fri Jul 27, 2018 3:03 pm
After I installed Oreo my notifications volume went very low - about 25% of the ringing volume. I was unable to find a way to change it though the settings. Third party applications are not working also - I tried Volume Control and Quick Volume Control but the notifications volume is still very low.
Any ideas?
ConkerVCL
Re: Notifications' volume cannot be changed
Sat Jul 28, 2018 6:41 pm
It's easy is an option in adjusting sounds right now I upload the steps
Mon Jul 30, 2018 12:32 am
Thanks for your feedback conker!
prascho
Mon Jul 30, 2018 9:27 am
ConkerVCL wrote:
Thank you for the information, but this just raises the overall sound level of the phone, which in my case is now working - the phone ringtone level is too high and the notifications sound is still much lower.  There is no way to make them equal, or to control the notifications sound level separately.
There are some third party applications that control this (Volume Control, Quick Volume Control, etc.), but they are not working with this ROM. Maybe there could be a control like this:
AleP
Tue Aug 14, 2018 8:09 am
1) try with different notification sounds.
2) can you send a video when you try to raise the volume of the notifications from settings and quick bar if possible?
prascho
Tue Aug 14, 2018 12:19 pm
It worked. I changed the default notification sound a few times and no the volume level matched the ringing volume.
Thanks a lot!
AleP
Tue Aug 14, 2018 12:41 pm
Thanks a lot!
Not at all!
Have a good day!
Admin, so this problem is solved?
Tue Aug 14, 2018 3:07 pm
Yeah, problem solved ;)
