Blackmamba
[SOLVED] bv8000 pro overheat
Fri Jul 27, 2018 5:52 am
Hello. I have problem with my bv8000 pro it is overheat and goes to 54C.Sometime is restart. please help!
Thank you in advance.
Re: bv8000 pro overheat
Sun Jul 29, 2018 11:50 pm
Hi there!
First, please perform a factory reset and check if this happens again.
Is overheating while under heavy use or in idle?
Blackmamba
Mon Jul 30, 2018 7:22 am
Hello.
I already reset the phone and flash it with the latest rom.
it is hot in idle
papapedrox
Mon Jul 30, 2018 7:39 am
The same for me, firmware 20180522_1555, always overheating after 10 minute of every task, even if is not heavy work.
Tue Jul 31, 2018 11:54 am
Blackmamba wrote:
Hello.
it is hot in idle
When did it start to overheat? since you got it or since you updated it?
Durant fatih
Thu Aug 02, 2018 8:37 am
Hello, i have also the overheating issue and high battery consumption. For example 10 minutes internet with mobile data spends 10% of battery and the phone is warm; more than 50 degrees. I already do a factory reset.
Thu Aug 02, 2018 9:58 pm
Same question: did it overheat since the beginning or after an update?
Durant fatih
Fri Aug 03, 2018 12:56 pm
It begins overheat since one or two month.
I did not upgrade it. I actually use 20171219 firmware, the most stable for me. My phone raises UP to 71 degrees with 10 minutes internet with mobile data.
Fri Aug 03, 2018 9:11 pm
This is not normal. Your device looks faulty. I reccomend to contact your seller to have it replaced under warranty,
Costantino
Sat Aug 04, 2018 5:47 pm
Sorry Admin....but do you think is acceptable that there are so many faulty blackview 8000? Most of us have the same problems: overheating and a dull charging-discharging behavior. What have we bought? Do something as soon as possible it is our right.....don't forget who spent the money.... I am quite angry, we pay and we deal with sellers....I would like to see blackview take a serious action instead of shrugging responsibilities.
Users browsing this forum: Google Adsense [Bot] and 2 guests
