peterscrivens
BV7000 power button inoperative
Tue Jul 24, 2018 10:13 am
Hi
The power button on my BV7000 no longer works, I can't turn my phone on. I have contacted the seller with no response, they no longer have an ebay shop. How can I resolve this issue?
Many thanks
Peter
Re: BV7000 power button inoperative
Tue Jul 24, 2018 10:32 pm
Hi there! you can replace thepower-on button module.
https://www.aliexpress.com/item/New-Pow ... 66973.html
peterscrivens
Fri Aug 03, 2018 11:01 am
That's great thanks. Can you send me the part please as it's less than a year old and still under warranty? Will I invalidate the warranty if I replace it myself?
Regards
Pete
Fri Aug 03, 2018 9:13 pm
Regards
Pete
If your phone is still under warranty, you should contact your seller to have it replaced/repaired under warranty.
Repairing it by yourself may void the warranty, as it happens also for every other phone...
