diogoaleff
smartphne with "no command"
Fri Jul 20, 2018 7:20 pm
smartphone presenting with the message on the screen "no command" can not give the hard reset some way to reinstall the operating system?
Re: smartphne with "no command"
Sat Jul 21, 2018 1:45 pm
can you boot your device in recovery mode and perform a factory reset? http://bbs.blackview.hk/viewtopic.php?f=192&t=334922
diogoaleff
Mon Jul 23, 2018 8:15 pm
I already did the hard reset anyway, it still has the same problem, it has times it returns to normal but when I turn it back to the same problem, is there any way to reinstall the room or root?
Tue Jul 24, 2018 10:14 pm
It looks like an hardware fault. I suggest to contact your seller to have your device replaced under warranty.
