Sebus
[SOLVED] Bv8000pro stuck
Fri Jul 20, 2018 11:29 am
I’m experiecing a problem with my bv8000pro. For 2 days my phone seems to be stuck. When trying to boot, the sequence stopped acteur few seconds and then the phone reboots. And again stopped, reboot and again and again.
When i try to use the contact link on blackview’s website, i get a message written in chinese, so i can’t know if it is ok.
Thank you for your help.
Sébastien hager.
Re: Bv8000pro stuck
Sat Jul 21, 2018 1:21 pm
Hi there! don't panic.
Can you check if the power button is stuck?
Sebus
Re: Bv8000pro stuck
Fri Aug 03, 2018 7:20 am
No the button is not stuck, i can push and release it freely, but there is no effect.
Thank you.
Re: Bv8000pro stuck
Fri Aug 03, 2018 9:25 pm
Sebus wrote:
Thank you.
Please perform a factory reset and report back if this solves your issue.
To perform a factory reset using the recovery mode, please refer to this thread:
viewtopic.php?f=192&t=334922
Sebus
Re: Bv8000pro stuck
Wed Aug 08, 2018 11:06 am
blackview_admin wrote:
Sebus wrote:
Thank you.
Hello, There is no way to perform a factory reset. When i try to enter the recovery mode, it's impossible and the phone is again and again rebooting, interrupting my attempt to enter in the recovery mode.
Thank you
Re: Bv8000pro stuck
Wed Aug 08, 2018 5:23 pm
If your phone is still under warranty, I recommend you to contact your seller to have it replaced.
Throbin_wood
Re: Bv8000pro stuck
Thu Aug 09, 2018 1:03 am
If the power button is not stuck take the rear cover off the phone and try reseating the ribbon cable to the button.
Does it make any difference trying to get to recovery if you have the charging cable connected?
Dose a pc recognise the device? Are you able to attempt a reflash?
