Dustyman042004
[SOLVED] Downgrade from.8.0 to 7.0
Mon Jul 16, 2018 11:32 pm
Can u downgrade from 8.0 to 7.0 using local update without broking your Bv8000 pro
Re: Downgrade from.8.0 to 7.0
Wed Jul 18, 2018 7:52 am
No, local update works ony for the Android 8 Rom. To downgrade, you'll have to flash your device.
lucky1guddi
Re: [SOLVED] Downgrade from.8.0 to 7.0
Tue Oct 02, 2018 9:38 am
how I can flash from 8.0 to 7
Tue Oct 02, 2018 8:02 pm
As you always did.
viewtopic.php?f=192&t=319505
