rajganesh.b
Blackview BV 9000 Volume down button problem!
Mon Jul 16, 2018 9:08 am
      I have a blackview BV 9000 mobile for which the volume down button is not working. Only volume up button is working. Can you guide me to any customer care center at Chennai-India?
Re: Blackview BV 9000 Volume down button problem!
Wed Jul 18, 2018 8:43 am
rajganesh.b
Wed Jul 18, 2018 11:22 am
Dear Admin,
                     There is no one from India. How can i resolve it myself? Can you guide me with any resolution?
Fri Jul 20, 2018 8:11 am
rajganesh.b wrote:
Dear Admin,
You have 2 choiches:
1) Contact your seller to have you device officially replaced/repaired under warranty.
2) Buy a case+buttons replacement from aliexpress https://it.aliexpress.com/wholesale?catId=0&initiative_id=SB_20180720000950&SearchText=bv9000+case+replacement
and let some unofficial repair centre replace it. With this option, you could void the warranty of your device.
