sakalzbaryn
[SOLVED] fingerprint unlocking
Sun Jul 15, 2018 1:49 pm
Hi, unlocking fingerprints works worse than on android 7 (unlocking faces probably does not work reliably)
Re: fingerprint unlocking
Sun Jul 15, 2018 4:32 pm
Can anybody else confirm such issue?
Santpj
Sun Jul 15, 2018 7:29 pm
That works well for me. Facial And fingerprint recognation are OK.
I m more confused by thé words "Down" And "Up" which are writed when I use fingerprint.
Luke
Mon Jul 16, 2018 1:08 am
For me it also works OK. Maybe you should try to remove a fingerprint and add it again?
I'm a software developer, see my projects if you're interested.
cizas123
Tue Jul 17, 2018 6:04 am
hi
Finger print improved it works better then on 7.0 its faster, more sensitive, works with bank apps in UK , face recognition never worked 100% for me sometime it working sometime it not , I think it depends from surrounding, light, whether etc.
I was researching and find out allot Bv8000pro on Ali express was sold with hello p20 but as far I understand Bv 8000 pro by black view supposed to be with helio p25 proccesor. So maybe some problems are related because of this?
AleP
Tue Jul 17, 2018 8:36 pm
cizas123 wrote:
hi
For the face unlocking try the Google Smart Lock face option in settings, trusted devices, face unlock.
Wed Jul 18, 2018 8:05 am
cizas123 wrote:
hi
No, this is not an issue.
