PietK
One year satisfaction, but . . .
Sat Jul 14, 2018 10:39 am
Dear Admin,
after using my Blackview happy for almost one year without problems (except flashing, see old posts), i did encounter suddenly a well known problem of the Blackview 7000 Pro: flickering / black / white / inverse colour screen using a certain screen-mode!!
See: viewtopic.php?f=175&t=216128
This happens often viewing a "full-screen"picture with camera, gallery or whatsapp, and also always starting a navigation app (Navionics). Need to reboot or lock/unlock to get the normal home screen which ALWAYS IS PRESENTED CORRECT. I tried the reset/whipe procedure
- Press Power and Volume up together for around 10 Seconds
- When the open android wit red triangel is shown press Power and Volume up together again for short time (WHICH FAILS FOR ME. . . nothing happens!!!)
Thus i did an erase using the standard Android procedure /settings/backup-reset.
Is anything known from a technical point of view on this problem, thus will a SCREEN-REPLACEMENT help or is it a real software issue??
Best Regards,
Re: One year satisfaction, but . . .
Sun Jul 15, 2018 12:54 am
Replacing the LCD should do the trick. It worth a try.
PietK
Sun Jul 15, 2018 9:51 am
Thanks, will report back as soon as LCD replaced
