sakalzbaryn
[SOLVED] it can not turn off the password when the phone is switched on
Wed Jul 11, 2018 2:31 pm
For example, when the phone is restarted, it can not turn off entering the first password after a scheduled switch-on. Therefore, calls and messages can not be received. Your phone still behaves as though it was turned off.
Re: it can not turn off the password when the phone is switched on
Wed Jul 11, 2018 7:48 pm
Sorry, but it can't understand properly. Can you explain the issue in a more detailed way? A video would help.
sakalzbaryn
Thu Jul 12, 2018 4:50 am
Hi, sorry, but I can not send a video now. The problem is that Android 7 was a "do not ask for a password after turning on the phone" feature (or something like that). This setting was different from the password on the locked screen.
AleP
Fri Jul 13, 2018 8:30 am
Try to create a new password in the settings. Then if you want that your device ask the password after reboot turn on the option or if you don't want turn It off.
After, if you want, remember to send the video, thanks.
ConkerVCL
Sat Jul 14, 2018 5:37 pm
View with most detail
Vista mas detallada
Sun Jul 15, 2018 12:40 am
Your hint seems to be correct ;)
AleP
Sun Jul 15, 2018 5:50 am
Try to set another password or find an option called "ask at start" or "ask at reboot" and disable it.
AleP
Sun Jul 15, 2018 5:51 am
sakalzbaryn
Sun Jul 15, 2018 1:38 pm
Hi thanks for the video exactly this problem I meant. Password recovery does not work, there is no choice in the menu (in android 7 was)
AleP
Wed Jul 18, 2018 4:58 pm
Did you try my solution?
