piruct
[TRACKED, WORKAROUND FOUND] SIM, software fault
Wed Jul 11, 2018 9:16 am
Good morning all.
After some hours perfect function with new update to 8.0 , sim stopped to work.
I'd go to the local dealer and him change my sim with a sostitute, wait all the night and nothing net on the BV8000 Pro.
Test the sim on other phone and it work well.
Go to buy another sim from a different operator, and nothing to do.
This morning downgrade to BV8000Pro_blackview_20180308 (7.0)and all go right , two sim on my phone and all it's ok.
Not a good experience.
I'm from Italy
Re: Back to Android 7.0 Sim fault
Wed Jul 11, 2018 7:14 pm
Issue is now tracked.
bilyj
Re: [TRACKED] SIM, software fault
Thu Jul 26, 2018 10:22 am
I have another problem with sim-card. Sim work normal like before update, but cell phone always show "Sim card changed". I think it's happening when phone connect to another cell site.
bilyj
Sat Feb 02, 2019 5:59 pm
I found the reason for the showing of the error - "Sim card changed". It happen while chosen "Ask every time" in "Settings/Network & Internet/Sim cards/SMS message/Select SIM card"
Thu Feb 07, 2019 10:26 pm
Thanks for your feedback!
