Santpj
[SOLVED] Update to Oreo impossible.
Mon Jul 09, 2018 3:19 pm
I downloaded 2 times following the link.
Put the 2 files in different path
Tried the 2 methods.
It always stop after the verification.
Someone with the same trouble?
Don Harry
Re: Update to Oreo impossible.
Mon Jul 09, 2018 3:22 pm
Have you taken the storage card (if installed) out?
BJSr
Mon Jul 09, 2018 3:33 pm
Did exactly the same, with the SD card installed, same result: verify fails after 20 sec.
Don Harry
Mon Jul 09, 2018 4:11 pm
My expirience with older versions was, that it only works WITHOUT a installed SD card.
BJSr
Mon Jul 09, 2018 4:23 pm
As a conclusion to the information given in this forum; I will wait till a functional oreo is released. This first version should be filed under "experimental" and avoided at all cost!
Have a nice day!
Rgaspar
Mon Jul 09, 2018 5:42 pm
Santpj wrote:
i had the same trouble. i solved it by downgrade to 20171219 build and then used the 2nd method.
Santpj
Mon Jul 09, 2018 6:07 pm
Rgaspar wrote:
Santpj wrote:
Thanks Rgaspar,
That s why I asked on other topic what fw was installed to people who reached the update.
I wait for answers.
If I know that with older fw the upgrade is possible, I ll do.
Santpj
Mon Jul 09, 2018 6:10 pm
Really,
I did many update with my SD Card In.
I put the zip files in SD Card, and in internal memory.
Both didn't work.
bluew
Mon Jul 09, 2018 8:48 pm
Doesn't work for me either.
Method 1: "Signature verification failed"
Method 2: not able to see any files? (no sdcard)
michele.mignini
Mon Jul 09, 2018 9:47 pm
I agree with other users. For those who don't manage to install it, just downgrade first to an earlier ROM (from January for example) and then install the newest ROM.
Although, after having installed it, I would recommend anyone to just wait for further development, since this ROM is not perfectly functional.
