BJSr
BV8000Pro_blackview_2018062921 feedback.....
Sat Jul 07, 2018 7:51 pm
Hi.
I performed a local install of the Android 8.0 released today. Yes i did perform a Factory reset. Result is : system reports Android 7.0, same version of firmware as before i started!
A lot of work for no use!
Thanks!
Santpj
Re: BV8000Pro_blackview_2018062921 feedback.....
Sun Jul 08, 2018 8:19 am
Same for me here with fw 20180307 impossible to upgrade to 8.0
Sun Jul 08, 2018 8:29 am
BJSr wrote:
Hi.
Thanks!
Did you follow the first local update method or the second one?
viewtopic.php?f=192&t=436084
BJSr
Sun Jul 08, 2018 8:37 am
Hi. I used the first method.
MadMax
Sun Jul 08, 2018 9:45 am
Installed 8.0 via Local Install ( first method ) all works well, except the navigation lights don't work anymore, they don't light up, navigation however works fawless!
Sun Jul 08, 2018 10:30 am
Try to use the second one, then report back ;)
Sun Jul 08, 2018 10:31 am
Did you perform a factory reset after the update?
MadMax
Sun Jul 08, 2018 11:24 am
Hello Admin, yes i did perform a factory reset, as always :)
MadMax
Sun Jul 08, 2018 11:27 am
BTW: Local Install ( first method ) forces you to perform a factory reset before the phone boots, at least for me :)
banane99
Sun Jul 08, 2018 12:23 pm
I´ve updatet one of my BV8000Pro via local update+factory reset and so long it works fine. I will further test it. Hope BT is now working stable. So long it was a mess.
