Koos
P10000 speaker volume
Sat Jun 30, 2018 12:19 pm
At maximum volume I still struggle to hear what people are sying
How do I increase the volume setting in engineering mode?
Bobberroo
Re: P10000 speaker volume
Mon Jul 02, 2018 7:23 pm
The speaker on my P10000 has stopped working.  I tried following the instructions in these links but I nothing has changed.  In fact, I can't even find the loudspeaker settings in the MTK Engineering Mode menu - my screen is quite different.  Can you suggest other ways to diagnose and/or correct this problem?  Thanks.
Tue Jul 03, 2018 8:09 am
It really looks like an hardware fault.... you'll have to contact your seller to have your device replaced under warranty.
Koos
Thu Jul 05, 2018 6:19 pm
Hi
Your engineering mode options are very different to mine
- Hardware testing -> Audio ->Volume -> Voice-> ??????????
Please advise
People phoning me now complain that there is a lot of echo on the line
Koos
Thu Jul 05, 2018 7:15 pm
I would also like to reset the volume settings in the engineering mode - please explain how to do that
Thu Jul 05, 2018 9:41 pm
to reset volume settings in engineering mode, just perform a factory reset of your device.
Start considering about an hardware fault, to be managed by contacting your seller for a replacement under warranty.
Koos
Mon Jul 09, 2018 6:55 am
Hi
Please respond to my post from a week ago.
I mentioned that my engineering is different to the one's that you posted
Please explain which variables to I increase?
Thank you
Mon Jul 09, 2018 7:46 am
A specific tutorial will come soon.
inoeps
Sun Jul 22, 2018 8:13 am
Did the blackview P10000 only had 1 speaker on the phone?
I just got mine 3 days ago and the seller said that the phone only had one speaker and the other sound grill only just for decoration purpose.
Thank You
