Sonoitaliano1
[SOLVED] Screen broken and Charge problem
Wed Jun 27, 2018 1:25 pm
a week ago I slipped the phone from my hands and fell on the screen ... it cracked I do not know why I saw so many videos where they dropped it from several feet and did not do anything ... I bought a screen on Amazon and I replaced it now I'm not sure if it's still Ip-68 or not. P.s. adhesive strips were also supplied. In addition I also have another problem that occurred before and after the fall or when I insert the connector of the device from the charge and then stops it again and I have to put the device in a certain way to make it load. Now do I have to replace this piece or not? To understand better, this is what my phone does : https://youtu.be/DZf9ghRDTXc
Re: Screen broken and Charge problem
Wed Jun 27, 2018 7:26 pm
Hi there!
1) Being a rugged phone doesn't mean it doesn't follow physics rules...
2) If you replaced the display in the right way, it should be ip68 again (remember the orings on the screws!)
3) Your USB port seems to be faulty. I suggest to replace the charging board. You can find it here:https://it.aliexpress.com/wholesale?catId=0&initiative_id=AS_20180627112535&SearchText=bv8000+pro+charging+boartd
