cerebro84
Wifi with login
Sat Jun 23, 2018 7:00 pm
I'm using two sims and the data is enabled on the second sim. Sometimes I need to connect to FON networks, that require login before giving internet access. The problem is that the login page is not working unless I disable the mobile data (forcing the phone to use the wifi). Is there any workaround?
Re: Wifi with login
Sun Jun 24, 2018 12:19 am
Fon networks are wifi networks: to connect to them you'll have to switch on your wifi module, and this disables the mobile data network.
It's all normal!
