Jimiest
Battery Charging Temperature
Fri Jun 15, 2018 10:05 am
I would like to know what´s the normal charging temperature. My P10000 Pro it´s about 55 celsius degrees while charging and i feel the terminal very hot.
This is normal? I saw another unit from my mate and his hasn´t this problem...
Thanks!
Re: Battery Charging Temperature
Sat Jun 16, 2018 12:21 pm
Temperature depends also on apps activity.
If you play or watch videos while charging, it's normal that the charging temperature will be higher.
Jimiest
Mon Jun 18, 2018 8:08 am
Ok, thanks for answering!
Sat Jun 23, 2018 1:52 am
MRUK wrote:
I have the same issues with my P10000 although im not using any apps and using the official charger and cable most time warning appear telling me to hot.
What to do?
Your unit seems to be fauly. Please contact your seller to have it replaced under warranty.
