ant0ni0
Maybe I brick my A7 pro
Fri Jun 15, 2018 9:49 am
Hello everybody, because my smartphone is in loop and brick, I try to flash original rom *.tar file by SP Flash Tool, but I get this error message in the picture  https://www.dropbox.com/s/svhbnya2nk47o12/errore.jpg?dl=0
ERROR : S_FT_ENABLE_DRAM_FAIL (4032)
[EMI] Enable DRAM Failed!
[HINT]:
Please check your load matches to your target which is to be dowwnloaded.
How I can solve this problem ?
Thank you.
