The new BV9500 and BV9500 Pro indestructible smartphones are coming!
Fri Jun 15, 2018 6:31 am
Hi there!
The new BV9500 and BV9500 Pro are coming! :D
Join the Indiegogo campagin to get a special limited offer!
https://www.indiegogo.com/projects/the- ... oming_soon
Once the june prelaunch will end, all the people that joined the mailing list will receive all the infos, and a special limited offer!
Here are some specs!
Body size: 163.2*80.8*18.7MM
LCD Screen: 5.7inch FHD+ IPS1080*2160
Touch screen: 5@points G+FF Corning Gorilla special explosion-proof glass
Battery: 11.000 mAh BAK Battery (HUGE!!)
Camera: Sony 16MP Dual Rear Camera
CPU: Helio P23 Octa-core Processor
Memory: 6GB Ram / 128GB Rom
Protection: IP68, IP69K, MIL-STD-810G (Test Method 501.5 High Temperature, Test Method 502.5 Low Temperature, Test Method 514.6 Vibration, Test Method 516.6 Shock)
Connectivity: 2 SIM card slots, supports all frequencies available in the world!
Operative system: the latest Android 8.1
Geolocalization: GPS & Glonass
Sensors: Proximity, Air pressure, Gesture, Gyroscope, Magnetic, Compass, Fingerprint, NFC, Coulomb Counter
What's the difference between the BV9500 and the BV9500 Pro?
The BV9500 Pro comes with 6GB Ram / 128GB Rom and a removable antenna, wich enables the interphone/walkie talkie function (works on 400-470 frequencies, for 350-390 should be requested from customized requirement). The BV9500 comes with 4GB Ram / 64GB Rom and lacks the walkie talkie support.
For any questions, feel free to post here!
Parcheval
Re: The new BV9500 and BV9500 Pro indestructible smartphones are coming!
Wed Jul 25, 2018 3:17 pm
When are the first shipments planned?
Parcheval
Fri Aug 10, 2018 7:02 am
Any news?
naim
Thu Sep 13, 2018 8:31 am
Hello Admin
I have a question about walkie-talkie function: what is the ERP (radiated power, in Watts)? Is it adjustable by the user?
Thanks
styxxx
Sun Oct 07, 2018 12:58 am
No Galileo GNSS support?
Fri Oct 19, 2018 3:00 pm
naim wrote:
Hello Admin
Thanks
No, it can't be adjusted.
Fri Oct 19, 2018 3:19 pm
GPS, GLONASS and A-GPS are more than enought :)
Galileo will be supported in a near future.
huw9911
Mon Oct 22, 2018 5:19 pm
i have a problem with the BV9500, when i go outdoor to other state with no 4G coverage the phone automatic change to 3G band and i can't receive any call or data from 3G band , i have to manually go to network menu and change the prefer band to 3G to enable to receive call and data .Same when i get back home the phone still stuck with 3G band and i have to manually change it to 4G to receive call and data.In the network menu there is no selection for automatic select ,only 4G ,3G and 2G and i have to force to select only one of them,please fixed the problem, other than that the BV9500 is a good phone everything work perfectly.
azarashi
Mon Oct 22, 2018 10:42 pm
Hi, Administrator, I bought BV9500 with using BV8000Pro for 1year. BV9500 is nice phone, good construction and performance.
Does BV9500 have VoLTE and DSDV feature?
Those make BV9500 perfect. Appreciate software update.
BTW, BV9500 does not have engineering mode which is useful to know LTE configuration. Hope it coulde be added in future.
BR,
Azarashi
Mon Oct 22, 2018 11:14 pm
BR,
Azarashi
VoLTE is supported by the device, but it has to be supported also by the phone carrier. DSDV unfortunately isn't supported.
Users browsing this forum: Idellacjw and 3 guests
