ean81
Cycle reboot (bootlop) after replace LCD
Sun Jun 10, 2018 10:36 pm
Hi! I bought the screen on Aliexpress. After replacing the screen, the phone is constantly rebooting. If I install firmware C306_JK_0413, then everything is fine, but when installing updates again a constant reboot. What can you advise?
if I update the files boot.img (with boot-verified) and lk.bin (with lk-verified.bin), there will be an endless reboot, or a strip on the screen instead of an image. I need these files for a new firmware (22/06) with drivers from the old firmware (13/04).
Re: Cycle reboot (bootlop) after replace LCD
Mon Jun 11, 2018 3:34 pm
Did you phone ever had such problems before replacing the LCD?
ean81
Tue Jun 12, 2018 4:45 pm
No. With broken LCD smartphone working fine.
With latest firmware:
https://drive.google.com/file/d/1G9nxo3 ... p=drivesdk
With firmware 04/10:
Fri Jun 15, 2018 11:07 am
Yeah, you should replace your LCD scrreen with another one. Try to get a different part number/code.
ean81
Fri Jun 15, 2018 11:31 am
Ask developers to add drivers for this LCD-screen to the latest version of the software. In the first version there is a driver for this LCD screen.
Or tell me how to fix a bug with microphones. In which file to change which parameters?
Sat Jun 16, 2018 9:29 am
Just asked. ;)
