The solution for sim card reading problem after firmware update via local update
Wed Jul 06, 2016 7:48 am
Dear BV6000 users,
So sorry for the problem of sim card reading after you chosed update to BV6000_Blackview_V01_20160630 firmware.
Now there is solution to this problem.
1) Download the provided firmware zip file via the following link:
https://mega.nz/#!ul1mxIYI!9SXNzZ3SbeAz ... o_90FaDykA
2) Copy this file to the TF card or the internal storage of BV6000.
3) Follow the below steps
a) find "about phone " on setting menu
b) tap the "about phone" option to find "wireless update"
c) tap the "three point area"
d) When the step "C" finished, you will see the following interface.
Now choose the " local update " option
e) Just select the zip file that you have put in the TF card or internal storage to start the update.
Hope such a local update will help you solve the problem .If still have any question or problem, just post under this topic, then we will
reply you as soon as possible.
Thanks so much for your support and understanding.
Best regards,
Admin
dabomb
Re: The solution for sim card reading problem after firmware update
Wed Jul 06, 2016 9:05 am
Thanks for finding a fast solution. :D One Question: I flashed the phone because of the Sim Card Error back to the previous 20160608 Version. Can I update now your "new" firmware or do I have to update the 20160630 first?
The Master
Wed Jul 06, 2016 9:07 am
Whoa! It works! Best soluton, without any kind of flashing! Tnx a lot!
Wed Jul 06, 2016 9:18 am
this solution is just suitable for the one who updated to the 20160630, then troubled by the sim card reading problem.
Best regards,
Admin
mikhail
Wed Jul 06, 2016 9:19 am
Thank you! The efficiency of the phone is restored! :P :P :P
Wed Jul 06, 2016 9:33 am
Feel very happy to hear such a good news.
debrick
Wed Jul 06, 2016 12:34 pm
Seems to be working fine :) Thnx a lot , i was really afraid to flash the phone
AERO
Wed Jul 06, 2016 4:28 pm
Thanks!
j1bv6000
Thu Jul 07, 2016 2:27 am
Thanks for the revised update.
Phone is working now.
Please check your ROM before publishing, it'll save many people a lot of inconvenience and save your company a lot of bad publicity and reputation.
Anyway, appreciate your quick response.
Thu Jul 07, 2016 6:48 am
feel very harry to hear that the problem is solved.
Best regards,
Admin
