Strikeiron
[SOLVED] New problem: BV8000pro doesn't recognize a brand new microsd
Sun Jun 03, 2018 10:00 pm
As described in the title I bought a brand new microsd Sandisk but BV8000pro doesn't recognize it. Same microsd is seen by computer and other cell phones...What could I do to solve the problem? Thanks in advance.
Re: New problem: BV8000pro doesn't recognize a brand new microsd
Mon Jun 04, 2018 3:09 pm
Hi there! Did you format it on the BV8000 pro?
