Neville
[SOLVED] Menu button not working in FW 20180522-1555
Fri Jun 01, 2018 1:58 am
The Menu button no longer calls up multitasking apps in the latest 20180522 update
Re: Menu button not working in FW 20180522-1555
Fri Jun 01, 2018 7:13 pm
In no way? is the menu button completely off?
Neville
Sat Jun 02, 2018 2:54 am
No, it appears to have been accidentally reprogrammed by the firmware in both the new phones we updated. Instead of bringing up the list of open apps, pressing the menu button now appears to trigger the same action as pressing a blank space on the home screen - it calls up widget and wallpapers menu.
Sat Jun 02, 2018 11:28 am
OK, what about keeping it pressed for a long time or pressing it 2 times very fast? what happens?
Neville
Sat Jun 02, 2018 1:08 pm
Tried that when it first happened, makes no difference. Just toggles between home screen and widgets/wallpapers mode. On both phones. I am assuming others have noticed.
Sat Jun 02, 2018 1:49 pm
ok, i'm marking it as tracked! Thanks for the help, Neville!
Rgaspar
Re: [TRACKED] Menu button not working in FW 20180522-1555
Sat Jun 02, 2018 5:24 pm
in mine, long press brings all apps open
Sun Jun 03, 2018 4:31 am
 Got the 20180522 firmware?
Neville
Sun Jun 03, 2018 9:57 am
You are right..I thought I had done a long press but obviously not long enough...problem solved.. Thanks Admin and Rgaspar.
Mon Jun 04, 2018 3:16 pm
lol, time to close this thread :D
