Geo3
[SOLVED] USB C cable does not seat properly / charge does hold
Wed May 30, 2018 11:39 am
Two weeks out of the box and USB C cable does not seat in charger port firmly. With extended head length needed by BV8000 Pro, cable received in box was only cable that initially worked with device. Now cable does "grab" and will slide out unless positioned correctly.
When a full charge does occur, batter life is less that 5 hours of total life.
I like design, feel and function of device as I'm testing for deployment in an construction environment at a contractor in New York. I am not a tech personally and my IT staff does not service this level of device.
Any suggestions to restore functionality (and where to get extra USB C in America)
- Geo3, new user in NY
Re: USB C cable does not seat properly / charge does hold
Thu May 31, 2018 9:54 am
Hi there!
1) If your original cable is damaged, you can buy another one here for few dollars:
https://it.aliexpress.com/store/product ... 49203iVZNd
2) if your USB-C port is damaged, you can replace the whole charging board. Here you can find replacements:
https://it.aliexpress.com/wholesale?cat ... o+charging
3) what's your current firmware version?
Geo3
Thu May 31, 2018 2:09 pm
BV8000Pro-Blackview-V0.1_2017083
Fri Jun 01, 2018 7:07 pm
Please post me a screenshot of the "Firmware upgrade" app.
Geo3
Wed Jun 27, 2018 7:20 pm
How do I open or find the "Firmware upgrade" app?
Wed Jun 27, 2018 7:37 pm
You should find it under settings -> about
Geo3
Thu Jun 28, 2018 5:01 pm
Here is the screenshot.  I am disappointed that the USB-C board broke in less than 1 month.  I am not hobbyist and really don't want to take my phone apart to fix it.  I've have Blackberry, Nokia, Microsoft, and Sony devices without ever having to fix the innards.
alewismclean
Fri Jun 29, 2018 7:29 am
I have the same issues with my BV6000. Very loose USB cable for about 4months now and the phone is less than a year old.
New USB cables and they only fit ever so slightly better.
Phone doesn't charge while I'm using it now and after 8hrs charge overnight it only gained 60%
I'm now fighting with Amazon about this and having very little luck. I have all my work contacts on this phone so it's dangerously unreliable for me.
What's the manufacturers warranty?
Fri Jun 29, 2018 8:08 am
USB port (and cables) should be carefully managed...  maybe you went a bit hard on them.
Geo3, If you don't want to open the phone by yourself, you can always buy the new charging board and let a phone repair center do the trick.
Here are some official repair centers near your country: http://blackview.hk/global-agents/
alewismclean, here we are talking about BV8000Pros, please post under the BV6000 section.
The seller will honor warranty: with amazon you won't have any kind of problem ;)
