yvan
[SOLVED] Bluetooth associations lost, Back button and ads
Tue May 29, 2018 12:45 pm
My bv8000 pro begins to get on my nerves.
Screen sensitivity is quiet bad.
It suddenly lost all my Bluetooth associations, I use use it for professional use and it should be a professional unit...
The back button is a real nightmare, some applications really need it. if you switch on/off, you (sometimes) have access to it again.
Problem of ads I never encountered with all my previous phones.
The promess to have a rom enhancement engage only people who believe in it, still waiting.
Don't forget you make technology, not politic...
Those unit might also done to be used, not only sold...
Sincerely
Re: Bluetooth associations lost, Back button and ads
Tue May 29, 2018 1:17 pm
What's your current firmware version?
Kryogenius
Tue May 29, 2018 3:34 pm
Hi
i have the last version by OTA BV8000Pro-BlackView-V0.1_20170803_20180522-1555
I have done a factory reset (once again)
and i notice the same problem : bluetooth associations is not permanent.
On/off actions is the only way for the moment for restore associations. For me doing this, once the bv8000 reboot !
Thanks
Wed May 30, 2018 2:20 am
Kryogenius wrote:
Hi
Thanks
did you notice the bluetooth association issue also on previous firmwares?
Kryogenius
Wed May 30, 2018 7:01 am
blackview_admin wrote:
Kryogenius wrote:
Hi
Thanks
Hi
nope, i have problems only with this last version.
yvan
Wed May 30, 2018 7:23 am
my firmware is BV8000Pro-Blackview-V0.1_20170803_20180307-1950
any solutions to solve those huge bugs ?
Sincerely
Yvan
Wed May 30, 2018 12:00 pm
Kryogenius, just downgrade to your previous firmware for the moment.
Kryogenius
Thu May 31, 2018 6:59 am
Hi
nope, it's not essential for me just for phone on car : i can do differently.
i will wait the next one or oreo, i'm fed up to reinstall all apps after reset :)
Thanks for the solution
yvan
Re: [SOLVED] Bluetooth associations lost, Back button and ads
Fri Jun 01, 2018 12:35 pm
Why do you notice this topic as "solved" ? If downgrade firmware, then problems of ptt button are back (and some other bugs)
And what about the back button problem ?
Sincerely
Yvan
Fri Jun 01, 2018 8:20 pm
Sincerely
Yvan
Topic has been marked "solved" because a firmware downgrade will solve the bluetooth association issue (not cared, in the end, also from the user who opened this thread...).
The back button behaviour can't be considered a problem... and i use the BV8000 pro evey day... so i know what i say.
