[TRACKED] After 20180522 firmware update, alarm clock doesn't work anymore
Mon May 28, 2018 8:24 am
I'm reporting what users said in another topic:
Neville:
Strikeiron wrote:
I installed the new firmware through its and I noticed that alarm clock doesn't work anymore. Before it worked: with cell phone turned off the alarm clock worked. Now it only gets the phone stuck (in plane mode) without giving out any alarm.
Can confirm the bug...installed the OTA update on a brand new phone, factory reset afterwards. Alarm works fine if phone is turned on, but if phone is off it boots to a blank backlit screen with only the flight mode icon, battery percentage and time showing up the top. No noise and no response from buttons...it hangs and I have to hold power button down to force reset.
Reboots to a screen alert advising Alarm in in snooze mode. Alarm then sounded after a 15 min snooze delay.
AleP
Re: [TRACKED] After 20180522 firmware update, alarm clock doesn't work anymore
Mon Jun 04, 2018 4:21 pm
I can' t answer you, because I don't use the stock clock application anymore, but I can advise you a method to fix the problem, but without alarm with the phone turned off...
