Lucius
[SOLVED] Problem screen BV8000pro
Sun May 27, 2018 3:39 pm
hello BV team;
I've bought one of your product last year (june 2017) and since two days i can't start it even when i charge it. The recovery mode doesn't work either (Volume + start button) so i can't reboot it or download updates from my computer. I only have the red light when i charge it.
It's a Blackview BV8000 pro;
Re: Problem screen BV8000pro
Mon May 28, 2018 8:35 am
Hi there! unfortunately it seems that your device got a very bad hardware fault.
You'll have to contact your seller to have your device replaced under warranty ;)
Lucius
Re: [SOLVED] Problem screen BV8000pro
Mon May 28, 2018 8:56 am
Hi, thanks for your answer,
I bought your product threw the website Rakuten and the seller has disappeared!
Can you propose me any other solution?
Best regards
Louis
Tue May 29, 2018 10:04 am
Best regards
Louis
Very very bad news about your seller disappearing.... what the hell!
Next time you'll have to be more careful and stick only to trusted sellers :( i'm very sorry to read that.
I can suggest you to replace the charging board... for what it costs, it's worth a try. It may be the culprit.
https://it.aliexpress.com/wholesale?spm ... 0+charging
No other solutions, unfortunately :(
