serg2327
backup firmware + ROOT + TWRP
Sun May 27, 2018 3:52 am
has created a backup copy of the official firmware.
if you need someone you can download by link http://4pda.ru/forum/index.php?s=&showtopic=897494&view=findpost&p=73548124
I also ported TWRP and successfully received root access:  http://4pda.ru/forum/index.php?s=&showtopic=897494&view=findpost&p=73636702
noyce
Re: backup firmware + ROOT + TWRP
Tue Jun 05, 2018 12:42 pm
Could you please add a mirror from European hoster for A20 TWRP because I am a German user and can't understand or write Russian language, so I can't download from 4pda.
Thank you very much!
Nik
serg2327
Mon Jun 25, 2018 2:24 am
khaled radwan
Thu Jun 28, 2018 10:36 am
I wnat know if this root can be used for unlock the gmail in the a20 by using sp-flash-tool
serg2327
Mon Jul 02, 2018 6:49 pm
khaled radwan wrote:
Я не знаю, можно ли использовать этот корень для разблокировки gmail в a20 с помощью sp-flash-инструмента
To unlock google, flash the FRP section  https://mega.nz/#!NAkkSKJI!7GKtzlI-ZWFxclenJcLgsltku5qDtk2Fu4pMMAdPS4M
husnake
Wed Oct 03, 2018 5:25 pm
can i flash this twrp for my blackview a20 pro?
Taras
Thu Oct 04, 2018 7:47 am
https://4pda.ru/forum/index.php?showtop ... p=76086326
husnake
Sat Oct 13, 2018 8:01 am
ERROR 404
i can't download
Taras
Sun Oct 14, 2018 2:35 pm
husnake wrote:
ERROR 404
i can't download
https://4pda.ru/forum/dl/post/13606952/TWRP.rar
RapFan
Sun Feb 03, 2019 11:30 am
Hi there, i've flashed the backup you named "Blackview_A20_backupFT_2",  now when i boot up the smartphone asks for a password? what is that?
Maybe i need to unlock the gapps, but using the frp.img bundled in the archive i've got error "Obtain DRAM failed" "Please check you load matches to your target which is to be downloaded"
What do i need to do?
