vtkservicio
[SOLVED] BV8000 WON´T CHARGE
Wed May 23, 2018 12:35 pm
Hi, my phone won´t charge, and not appears on pc. It just appears a moment only when it's restarting as MT65xx Preloader and when the BV logo apears the computer makes the sound of disconnect so the cable is ok, when i plug the cable it shows as the battery charging but it does not move from 50%. I have a usb amperimeter that shows the phone is 0.00 [color=#222222][font=sans-serif]amps [/font][/color]consuming. Done factory reset. and still the same. The factory mode battery test shows the cable and charger connected but still no charge.
Here the pics
Re: BV8000 WON´T CHARGE
Thu May 24, 2018 8:55 pm
It looks like a faulty charging board.
You can contact your seller for a replacement under warranty or replace it by yourself (and maybe losing warranty).
https://it.aliexpress.com/wholesale?spm ... 0+charging
