serg2327
ROM download
Fri May 18, 2018 3:01 am
Since there are no official firmware P10000, I unloaded backup copies from my office phone
download it here: http://4pda.ru/forum/index.php?s=&showt ... p=73198552
the firmware data can be used to restore the phone.
Installed using a computer and the "SP Flash Tool v5.17..." in accordance with standard instructions
Re: ROM download
Sun May 20, 2018 9:55 am
Thanks for your effort serg!
Sigvarten
Re: ROM download
Tue May 29, 2018 9:16 am
following..
P_E_T_O
Re: ROM download
Fri Jun 08, 2018 8:24 am
there is a tutorial how to register at 4pda.ru, just google it,
or you can download 4pda app from google store, there is registration without captcha, and then just login with checked checkbox "Я не могу ввести ответ" -"I can`t reply" on the site, then login email will come
P_E_T_O
Re: ROM download
Tue Jun 12, 2018 5:24 am
if Serg allow me to upload the file and tutorial, only then can I upload it
serg2327
Re: ROM download
Mon Jun 25, 2018 2:21 am
