bsmith7
google pay
Thu May 17, 2018 6:54 pm
I installed google pay and it does not work.  I did not receive 20170822, that was fix.
How can I get 20170822 fix (for google pay) without having to install firmware.
Don't want to lose apps.
thanks
Re: google pay
Fri May 18, 2018 8:53 am
please post a screenshot of your firmware version of the "Update" app under settings.
bsmith7
Re: google pay
Mon May 21, 2018 4:43 pm
5-21-18
Dear Admin:
Thanks for reply.  Attached screenshot of update screen in settings.
I recently browsed to >  "check for updates" and downloaded: >(20180307-1950,
and this update appeared to be "reboot issue and translations").
I had tried (google pay) before the -1950 update, and then I tried google pay again,
after installing the above.
  (Google pay still does not work: I tried it at local department store,
and local dollar store and then Mcdonalds fast food).  No luck on Google Pay.  I moved phone
all around on terminal with (google pay) app open.  No response.
For some reason the phone did not alerted in notification on update, so
this may be why I did not receive any notifications during last part of 2017,
when the (google pay) fix was available.   So it appears that my phone does not
have (google pay fix).
Thanks for your time.
bsmith7
blsnra@reagan.com
616-635-8486 text/voice
Re: google pay
Tue May 22, 2018 8:28 am
bsmith7 wrote:
5-21-18
Dear Admin:
bsmith7
blsnra@reagan.com
Updates are incremental: the latest one carries all the previous fixes, the google pay one included.
Can you please perform a factory reset and try again?
bsmith7
Re: google pay
Wed May 23, 2018 3:50 pm
5-23-18
Dear Admin:
Thanks much for reply.  That's good news on updates being incremental.
Will do factory reset and try again.
thanks
bsmith7
