btprose
What USA carrier will BV9000 work with for real?
Sat May 12, 2018 5:46 am
This phone is turning out to be a complete scam because every site showing the specs on this phone says it will work with ATT and other GSM carriers and it DOES NOT work with any in USA!
Re: What USA carrier will BV9000 work with for real?
Sun May 13, 2018 3:07 pm
I'm sorry but as you can see in the bottom links, the BV9000 doesn't support USA bands.
https://www.kimovil.com/en/frequency-ch ... bv9000-pro
https://www.frequencycheck.com/compatib ... mit=Search
You can see that also on our official Aliexpress store:
https://it.aliexpress.com/item/Blackvie ... autifyAB=0
I can't understand where did you read different things about it...
StevenDorsey
Fri Aug 31, 2018 2:28 am
This link below has answerd the following questions with the folloing answers:
https://www.amazon.com/Blackview-BV9000 ... iew+Bv9000
can phone be used in u.s. for 4g if not is there a model that does support 4g
Answer --- The phone works with GSM network 850/900/1800/1900MHz. Please verify with your carrier
Also Doogee s60 same triple proofing
The phone works with GSM network 850(B5)/900(B8)/1800(B3)/1900(B2)MHz
By TRADEFARE Selleron February 23, 2018
[*]Will it work for us carriers such as at&t ect?
Answer --- Yes it will
By TRADEFARE Selleron February 6, 2018
Is this phone unlocked?
Answer --- yes it is
By TRADEFARE Selleron January 7, 2018
Sun Sep 02, 2018 10:40 pm
Tradefare doesn't know such details. Stick to what i told you a post above.
