Neville
[USEFUL] Faulty charging board can affect mobile signal strength
Tue May 08, 2018 5:03 am
Customer with new phone out of box reported very weak cellular reception.
Opened phone, found aerial was making connection with charge board as it should, but confirmed very weak signal regardless.
On a whim I replaced the charging board, and immediately gained 25dB of signal strength, indicating board itself had a problem.
Just a heads up if your signal is weak, it could be the board.
Re: Faulty charging board can affect mobile signal strength
Tue May 08, 2018 11:44 am
Thanks for your precious -as always- feedback Neville, i'll mark this post as USEFUL and make it sticky! ;)
cizas123
Re: [USEFUL] Faulty charging board can affect mobile signal strength
Tue Jun 19, 2018 9:15 pm
regarding improve signal strength, it have to done manually, like changing charge board?
any more options without opening phone?
Thanks
Wed Jun 20, 2018 8:20 am
cizas123 wrote:
Thanks
To replace the charging board, you'll have to open your phone.
