Cptn Shadoo
[SOLVED] No starting or no charging
Mon May 07, 2018 11:54 am
Last week, my bv8000 don't wake up like other days at 7:00 and from then I can't switch on
When it's on charge, the LED is always red, never green, and it been plugged for two entire days (plugged with the original cable and charger)
When I push the power button there is a very discret led in the cam blinking, but I can see only in dark place.
I made an update 15 days ago and no problems.
Thanks for your help
Re: No starting or no charging
Tue May 08, 2018 11:42 am
Hi there!
From what you say, it really looks like an hardware fault.
I reccomend to contact your seller to have your device replaced under warranty.
Cptn Shadoo
Re: [SOLVED] No starting or no charging
Wed May 09, 2018 7:20 am
Huuuum OK why not but I lost all in it ?
Photos etc?
Wed May 09, 2018 10:10 am
Yes, unfortunately. Unless you saved them in a MicroSD card.
