supertoaster2
[SOLVED] Startup Sound Disable On Phone - BV8000 PRO
Tue May 01, 2018 2:23 pm
Hi Support,
There is a lot of people who don't want to have the startup sound as there are occasion where it can embarrass the user if it reboots unintentionally:
  • At Work
  • At a Conference
  • At the Cinema
  • Waking everyone if reboots in the middle of the night?
  • various other occasions....?
So, please can you tell  us, how to modify the startup sound to be "NULL" and quiet, please?
BIG PLEASE!
Re: Startup Sound Disable On Phone - BV8000 PRO
Tue May 01, 2018 2:34 pm
Unfortunately you can't do it without rooting, and rooting can't be officially supported for obivous reasons.
An alternative would be setting your phone in silenced/vibration mode: until in such mode, the boot jingle will be silenced aswell. ;)
