marceloj.bueno
[SOLVED] Storing cloud updates.
Tue May 01, 2018 10:48 am
Dear Administrator, I would like an additional platform to be studied so that it can be stored and downloaded the updates since only the updates are available in MEGA, and its paid platform does not satisfy with satisfaction all the countries where Blackview is already .
Try a cloud that comes to meet globally and if possible free, since users in addition to acquiring the Mobile there has costs with the updates, which does not happen with other brands of mobile telephones are Android or not even Chinese brands like to Blackview.
Sorry for my english because I'm using the google translator.
Re: Storing cloud updates.
Tue May 01, 2018 10:55 am
You can download files from MEGA for free, you don't have to pay anything!
marceloj.bueno
Tue May 01, 2018 11:23 am
The problem is not so much to be paid or not, but the operation of MEGA in Brazil.
I only use MEGA to download the updates from Blackview and nothing else, even then the system informs that I used the entire transfer quota and that I can only download the file if I pay.
I believe that several other users may be having the same problem.
But if it is impossible or costly Blackview to have its updates on new platforms or even on a platform like Samsung or Apple, no problem, but continuing to suffer with MEGA.
Tue May 01, 2018 2:23 pm
I will forward such request to our team, let's see what we can do ;)
marceloj.bueno
Tue May 01, 2018 10:41 pm
Thank you
serg2327
Wed May 02, 2018 2:16 am
marceloj.bueno wrote:
Спасибо
mega free cloud and do not need to pay anything!
you just need to register.
create your cloud on the mega and there will not be any quotas
marceloj.bueno
Wed May 02, 2018 8:22 am
Note that the transfer quota is set to 0 (zero), making it impossible for you to download any updates.
There are bonuses that can be used and it is worth remembering that these bonuses expire a certain time, as happened to me.
Captura de Tela 2018-05-02 às 05.14.36.png (362.09 KiB) Viewed 3778 times
Captura de Tela 2018-05-02 às 05.10.14.png (372.62 KiB) Viewed 3778 times
Fri May 04, 2018 9:15 am
What about downloading ROM files from MEGA without logging into it?
marceloj.bueno
Fri May 04, 2018 10:32 pm
I was never able to download without being logged in.
Sat May 05, 2018 2:07 pm
I can (from Italy), and this means that there is something going between MEGA and your country.
You should use a VPN and see if something changes.
