aspirina
[SOLVED] speaker and cable
Sun Apr 29, 2018 10:18 am
mi altavoz distorsiona y el cable para cargar o conectar al ordenador se sale de su sitio solo, lo que obliga a estar pendiente de el y es imposible conectarlo al cargador del coche
¿que solución hay?
saludos
my speaker distorts what does not allow to listen well anything and the cable to charge or connect to the computer leaves its site alone, which forces to be aware of it and it is impossible to connect it to the car charger
What solution is there?
regards
Rgaspar
Re: speaker and cable
Sun Apr 29, 2018 8:19 pm
try to contact your seller and activate warranty. i have the loudspeaker problem and my seller is repairing. i believe that there is a official seller/repair store in Barcelona
Tue May 01, 2018 9:30 am
regards
Sorry but i can't understand what the problem is. Please write in a proper way to make me understand.
Rgaspar
Tue May 01, 2018 5:54 pm
i can explain: there is a problem with the cable connection to the phone that makes the cable loose and it disconnects by it self making impossible to charge the battery
Wed May 02, 2018 12:37 pm
Oh ok. He can buy another cable, if the cable is faulty.
https://it.aliexpress.com/item/New-Arri ... 69871.html
If device 's USB-C port is faulty, he will have to contact the seller to get a replacement under warranty.
Users browsing this forum: Google Adsense [Bot] and 1 guest
