piezzio
BV7000 Pro no sound, vibration and microphone
Sat Apr 28, 2018 6:34 pm
My bv7000 pro stop make any sounds from loud speaker, microphone not working and vibrations also. Tried to change small motherboard under battery and speaker under battery but no results. Anybody any tips? Cant give it for a guarantee because i opened it by myself i think. Thanks
Re: BV7000 Pro no sound, vibration and microphone
Mon May 14, 2018 12:06 am
If you didn't void any seal, warranty will be honored. Just contact your seller to have your device replaced under warranty.  ;)
