Legoates
Headphone and speaker working at same time
Sat Apr 28, 2018 4:53 pm
Hi BV
My 7000 pro been working fine for the last few months but the headphones still work but the speaker also working at the same time when headphones are plugged in . its not showing headphone symbol when plugged in but both working at the same time ?
Re: Headphone and speaker working at same time
Fri May 04, 2018 10:00 am
very very weird issue.
it may be an hardaware fault, but before directing to that, please perform a factory reset to set some variables. Then report back!
Legoates
Sun Mar 03, 2019 5:19 pm
Did a re set and the problem the same suspect its the headphones socket itself when you wobble it it seems to work then not and then both work internal speaker and headphones .
Given up and moved onto Bluetooth headphones which work well and connection is good gone for the Onkyo E200 BT . headphones supplied are totally useless and adaptor and sockets worked for a limited time .so the headphones socket become totally useless now .
Any one else struggling with headphones don't waste your money in corded the quality poor and they don't last .
Get a Bluetooth pair
