riyadsal
black screen issue in p6000
Tue Apr 24, 2018 10:26 pm
Hi
how i stop/disable proximity sensor in blackview p6000 because the screen coming black during call
best
Re: black screen issue in p6000
Wed Apr 25, 2018 8:36 am
This is an important feature, can't be disabled.
During call, if you put your device next to your ear, the screen will be disabled to avoid unintentional taps!
riyadsal
Thu Apr 26, 2018 1:43 pm
Thanks
my problem is how i can control my mobile with this
i cant open speaker , i cant open mobile for send anything during call before call end
more android mobile disable this or have setting to disable it as option
and this also happens when i play any sound massage in whatsapp the screen black
It's really annoying
please tell me if you have solution
Fri Apr 27, 2018 9:21 am
During call, just remove your phone from your ear and display will turn on again. Be sure to not cover the upper part of the display, where the proximity sensor is located.
