monusan
[In Progress] BV9000 Pro Microphone dead
Sun Apr 22, 2018 9:21 am
Dear Admin,
Please advise, my microphone suddenly dead, and I tried to use headset with usb c converter also not working...
I have factory reset but problem still occured, please advise is it hardware failure?
Thank you,
Regards,
Sanusi
Re: [In Progress] BV9000 Pro Microphone dead
Thu Apr 26, 2018 6:35 pm
Please try this and report if it helped:
