97gérard216
[Answered] Searching special Electronic component
Thu Apr 19, 2018 11:40 am
Hello Admin,
Can you give me a link to buy only this printed circuit board connector marked with a yellow arrow on the image.
Everything works, except the speaker, because I damaged the circuit by installing the new battery.
Notice to users of the BV9000 Pro: the battery is very, very difficult to take off if you want to change it. The strong glue is on the entire surface of the battery. As you can see, the printed circuit board is badly positioned when you want to lift the battery
Thank you
BV9000 Pro HD_circuit.jpg (358.54 KiB) Viewed 3660 times
97gérard216
Re: Electronic component
Thu Apr 26, 2018 7:30 am
Admin,
Have you had time to find me a link in order to buy the printed circuit board.
Thu Apr 26, 2018 4:10 pm
Sorry, I don't know a shop selling this special part. Maybe you can find one on aliexpress. If not please ask your seller to help you to get this.
Re: [Answered] Searching special Electronic component
Thu Apr 26, 2018 5:58 pm
There are some flex cables to buy on aliexpress. Don't know if is the correct one? https://www.aliexpress.com/wholesale?ca ... ble+bv9000
97gérard216
Fri Apr 27, 2018 1:08 am
by blackview_admin » Thu Apr 26, 2018 4:10 pm
Thank you Admin.
My seller is Magasin: BLACKVIEW Official Store. He said he did not sell this component.
I am moving towards another solution. If I find this component, I will put a link on the site.
