paddy007
[SOLVED] broken screen
Mon Apr 09, 2018 10:20 am
hi i recently dropped my phone and broke the screen to my amazement as i thought it was indestructable it is still under warranty do i send it back to you guys for a fix or replacement as i am struggling to get it fixed at a phone shop as there so unique phones please help me asap thanks
Re: broken screen
Mon Apr 09, 2018 12:28 pm
Hi there!
You'll have to contact your seller to have your device replaced under warranty, but i sincerely don't think that user damage will be covered, for obivous reasons....
By the way, you can buy a replacement screen and replace it by yourself (or by your phone shop if you're not handy).
Check this link!
https://www.aliexpress.com/item/5-0-Inc ... autifyAB=0
