naszerss
[SOLVED] No notifications on the app's taskbar
Sun Apr 08, 2018 5:52 am
No notifications on the app's taskbar when the screen is closed at all. Yes FW 20170803_20180105-1104 I need to fix it. :| :| :|
Re: No notifications on the app's taskbar
Mon Apr 09, 2018 1:52 am
hello,
did you install any antivirus programs?
if you did, please check the settings of the antivirus programs.
Mon Apr 09, 2018 12:22 pm
Please update your device to the latest firmware version, perform a factory reset and report back. ;)
naszerss
Re: [SOLVED] No notifications on the app's taskbar
Thu Apr 12, 2018 6:47 am
Thank you for all the answers.
I did not install the antivirus at first ...... wipe cash and factory data ... then it is not working .... the new FW is not ... do not ... would have to wait OTA alone. ..... When there is no app to notify tarkbar, some app does not work.
Sat Apr 14, 2018 11:41 am
Your actual firmware version (20180105) unfortunately carries a known bug (background task clear bug) wich makes also notifications not showing properly.
Updating your device to the latest firmware will solve the issue.
If you can't update it, a palliative solution would be going to settings -> "Background task clear", switch On such feature and put ALL apps on the white list, as we talked about is this thread:
viewtopic.php?f=191&t=345022
naszerss
Fri Apr 20, 2018 10:49 pm
Thanks to all the answers, you can go to Blackground task clear.. :D :D :D :D
