kavedel
[TRACKED] After update 20180308 phone won't go to deep sleep
Fri Apr 06, 2018 4:51 pm
After manual flash and factory reset the phone won't go to deep sleep.
Re: After update 20180308 phone won't go to deep sleep
Sun Apr 08, 2018 3:37 am
hello,
sorry but what do you mean by "deep sleep"?
kavedel
Sun Apr 08, 2018 6:55 am
With previous ROM version it was in deep sleep more than 60% of the time now it's like this.
Mon Apr 09, 2018 12:21 pm
Thanks for reporting such issue.
Can anybody else confirm such weird behaviour?
kavedel
Thu Apr 12, 2018 2:44 pm
Anyone else with the same situation?
voyager
Fri Apr 13, 2018 7:06 pm
Hello - I confirm same issue: after latest FW upgrade my phone doesn't go in deep sleep mode & my battery barely lasts for 2 days under moderate use.
I upgraded manually as OTA FW was not available.
Sat Apr 14, 2018 11:14 am
Did you perform a factory reset after updating?
voyager
Mon Apr 16, 2018 9:25 am
No, because the manual upgrade process to FW 20180308 already reset my phone and deleted all installed apps & settings.
Mon Apr 16, 2018 2:27 pm
Please perform a proper factory reset and check if the issue is still there.
McSusanin
Tue Apr 17, 2018 7:02 am
It's useless to drop to the factory on this firmware, the phone sleeps only on December and January firmware
