erieadnin91
Battery capacity of BV9000 Pro
Tue Apr 03, 2018 7:21 pm
Evening..
I bought this phone a month ago and realized that battery life and performance not as per mentioned which is 4180mAh. (Not long lasting, drain fast even in 'Batter Saver' mode)
After I run test using few apps, they stated the capacity is only 1000mAh.
I also following up with the previous topic about this battery issue but sadly no update for this matter. Please assist us to solve it. Thanks in advance.
1000mAh
1000mAh
1000mAh
1000mAh
Re: Battery capacity of BV9000 Pro
Wed Apr 04, 2018 6:59 am
hello,
please inform us your firmware version and then i will report it to the tech support team.
thx.
