eacenic
The update to Android 6 ??
Sat Jan 23, 2016 4:24 pm
Can be updated to Android 6 ??
Thank you in advance.
Re: The update to Android 6 ??
Mon Jan 25, 2016 6:04 am
hi ,
maybe not .
Best regards,
Admin
eacenic
Wed Jan 27, 2016 10:35 pm
Why not?
Sun Jan 31, 2016 2:20 am
eacenic wrote:
Why not?
The main Board can not support the system.
Best regards,
Admin
openminded
Mon Feb 01, 2016 9:43 am
What kind of a comment is that? Can you be more specific why the board would not support that?
There are kernel sources for mediatek devices for Android 6, so I see no reason why it should not be possible.
As usual, this just comes across as no real developers backing a product.
It would be really nice if one of the manufacturers finally gets that when devices are supported, more are sold.
Look at ZTE and Lenovo for example, publishing sources for most devices.
By the way, I have still not received an answer from any engineer to the question if the compass hardware is simply not available because of lacking drivers, or if the hardware is not setup properly.
As some users reported there is a sensor visible in CPU-Z.
If kernel sources and build scripts are provided, I would be happy to try and add a driver to the kernel for that sensor.
Cheers
Fri Feb 19, 2016 6:15 am
Cheers
Hi , the compass function is not supported.
And for BV5000 get android 6.0 , now still no news about this , if one day available , we will publish it .
Best regards,
Admin
