Bobberman
9000Pro FHD set-up wizard issue how to skip
Thu Mar 22, 2018 3:51 pm
Hello I'm having set-up wizard issue and I don't know how to I can skip the setup to launch ota upgrade.
Can anyone help me?
Lot of thanks
Re: 9000Pro FHD set-up wizard issue how to skip
Mon Mar 26, 2018 8:38 am
hello, do you mean you want to skip the upgrade of the OTA directly?
mr-senn
Wed Mar 28, 2018 8:22 pm
Just insert a sdhc card, it gives you the opportunity to select the settings menue and give the wizard all the authorizations it needs. After this the startup wizard will work its way through the options
Tue Apr 03, 2018 2:04 am
hello,
here is another way.
please try to do as follows:
disable all the wi-fi connections in the radius of the phone (because from the phone the wi-fi can not be disconnected), skip the procedure for the SIM, at this point it will ask you if you want to continue without connections and yes, do not enter the name and surname to give the phone a name, accept the Google / Android agreements, at this point the phone will be activated, no update is necessary via OTA if you have the BV9000 PRO-F phone (full HD version). There are two versions of this PRO series phone, the BV9000 PRO (not full HD) and the BV9000 PRO-F (full HD).
I hope this solution will work for you too.
