jman0
Oreo ROM's showing up on Needrom
Thu Mar 22, 2018 10:02 am
Hi.
I just received a notification email from Needrom. As I can see, two Oreo based firmwares for BV8000 Pro have already been uploaded there.
It says beta, so I guess it's not fully official yet. Or maybe you're launching a beta test program?
This is the link to it: https://www.needrom.com/download/blackv ... 000-pro-2/
Regards.
Santpj
Re: Oreo ROM's showing up on Needrom
Thu Mar 22, 2018 10:53 am
Is it an "official" beta Rom from Blackview?
If yes, how to subscribe to this program of beta test?
Thu Mar 22, 2018 5:40 pm
No beta test programs have been officially launched at the moment.
Guys, I wouldn't trust unofficial firmwares like this.
Just wait for the official one to come. You'll be able to help us debugging the official one in a near future ;)
rkolev
Fri Apr 06, 2018 5:50 pm
I tested the ROM at the link provided above and I must say there is one good thing about it - the flashlight when pressing the home button on the lock screen is working.
AleP
Mon May 14, 2018 5:37 pm
But the what is the Android version shown in the settings?
If is 8.0.0 you can download and see works apps like substratum or apps reserved at Android O?
Oh and it is rooted?
jman0
Tue May 15, 2018 7:39 am
It's 8.0.0 and it's definitely Anroid O, but not all things work well, because it's probably a leaked development version, not the final one. I found some apps not working (Google Play Store says they are incompatible). I also tried sideloadling the apk's, but they don't install, so they look truly incompatible. Something BV will have to address before releasing it.
It's not rooted, as it happens with all Blackview official rom's.
I'd only suggest using if you don't mind testing software, but it doesn't enter deep sleep, so battery usage is very high, some apps don't work, and it's not 100% stable yet (I guess that's why BV have not oficially released it yet). I'm using it everyday, but I'm used to testing software on pc's and smartphones.
BTW, the camera quality has improved significantly, as it takes photos with way less noise than before, and the hdr mode now makes a real difference, although the camera app is still a bit unstable.
AleP
Tue May 15, 2018 2:41 pm
Wow, thanks for all!
dasiro
Thu Jun 07, 2018 6:23 am
still no updates on "soon" ?
Fri Jun 08, 2018 9:31 am
Nope.
